CAM CAP BOLTS
sockpuppet
CAM CAP BOLTS
#1 PostAuthor: sockpuppet » Sun Sep 04, 2011 9:05 pm
Can anyone please tell me the length for the bolts that hold the camshaft
caps on a Gpz1100b2 :?:
I`ve just noticed mine are different sizes ! :roll:
some are 45mm and some 50mm , also some plain tops and some No7 :yay
What should they be ?
Mick
#2 PostAuthor: z1bman » Sun Sep 04, 2011 9:09 pm
92002-1881 BOLT,6X43 x 16
sockpuppet
#3 PostAuthor: sockpuppet » Sun Sep 04, 2011 9:13 pm
I assume the longer ones have been put in at sometime to get round the dodgy threads ! :roll:
Mick
Garn 1
#4 PostAuthor: Garn 1 » Sun Sep 04, 2011 10:28 pm
SockPuppet, as you say, these bolts have often been extended "to get around dodgy threads." It is often a lot easier then "helicoiling". There is a fair bit of meat under these bolts and they can often be cleverly drilled and tapped to accept these longer bolts.
I have found the use of hex socket headed bolts give a better feel, when "torquing up" and avoid stripping these threads.
Users browsing this forum: Bing [Bot] and 47 guests
