Hung rev counter
toycollector10
Hung rev counter
#1 PostAuthor: toycollector10 » Sat Sep 24, 2011 1:12 pm
Hi, my tacho is sitting at 2000 RPM when the engine is off. When I am riding the bike the revs fluctuate between 2000 and 5000 RPM. No higher. If I tap the face of the tacho the needle slowly jerks down to the zero stop. I'm reluctant to cut into the chrome band to have a look inside and I'm also not keen to squirt lubricant into the back of it in case it weeps up and out onto the face. I have only put about 6000 miles on a brand new tacho cable so I don't think that's the problem.
Any ideas?
#2 PostAuthor: z1bman » Sat Sep 24, 2011 1:22 pm
i would say you have only got two options. get the one you have got professionally re furbished or replace with a new replica
Mark Tiller
#3 PostAuthor: Mark Tiller » Sat Sep 24, 2011 3:32 pm
With a small screwdriver you can open the band up by working your way round with it face down
07962421462
mick znone
#4 PostAuthor: mick znone » Sat Sep 24, 2011 3:56 pm
the damping fluid has gone south, they can be fixed by those in the know, i believe there is also a magnet inside that looses its strength. best to get it fixed by a pro, its a closely guarded secret what fluid should be used.
i have heard that the repro units are very inaccurate, nut havnt tried one myself. also, thy do not have the ND on the face so are easily recognised as a repro, unless you put an original face on a repro clock, but this would cost as much as having yours fixed. hope this helps.
KeithZ1R
#5 PostAuthor: KeithZ1R » Sat Sep 24, 2011 4:03 pm
Al Marshal 's your man
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
