RESISTOR
Hawk1
RESISTOR
#1 PostAuthor: Hawk1 » Mon Sep 26, 2011 8:51 pm
One Question please.
Do have Boyer + Accel 140403 coils witch needs resistors.
Bike is KZ1000 ´78.
Going to put 1.ohm, 25watt on each coil. Have one RED/Yellow from
ignition switch (power) to the coils witch spits into "Y" to both coils.
One Green connects to RH coil and Black to LH coil.
The Red/Yellow power from switch splits into "Y" both coils.
Question is: Do I set the Resistors on the LH coil Red/Yellow and
the RH coil green wire or the wire witch goes into "Y"
If Ii is RED/Yellow wire then it seems that I have two resistors on the "Y"
Hope you understand this explanation.
Thanks in advance :??
Z1000A2,
ZRX 1224S
Riding Safe Is Smart.
Hawk1
#2 PostAuthor: z1bman » Mon Sep 26, 2011 10:38 pm
they have to be connected to the positive feed to the coils if there are two coils you will need two resistors
Hawk1
#3 PostAuthor: Hawk1 » Mon Sep 26, 2011 11:26 pm
Thanks I got it z1bman
Thanks for your reply.
Z1000A2,
ZRX 1224S
Hawk1
