kz1000 a1 engine mounting bolt.
stephenh
#1 PostAuthor: stephenh » Mon Oct 10, 2011 12:23 pm
Hi all
does the kz1000 a1 have a single front engine mounting bolt,as shown in the european parts book,my bike has two shorter bolts fitted.
cheers steve.
#2 PostAuthor: z1bman » Mon Oct 10, 2011 1:03 pm
should be a single bolt 10x310mm long
part no 92091-022
stephenh
kz1000a1 engine mounting bolt
#3 PostAuthor: stephenh » Mon Oct 10, 2011 2:00 pm
thanks for the info....i just have to find one now
cheers steve
zedtwo
#4 PostAuthor: zedtwo » Mon Oct 10, 2011 2:52 pm
I might have one of the type which are threaded at both ends to allow for engine bar fitting,will let you know in the next couple of days :!:
Rob Lafferty
#5 PostAuthor: Rob Lafferty » Mon Oct 10, 2011 6:54 pm
Steve
May have a spare set in the garage of NOS.
1 is 310mm long and the other is about 250mm.
Had them to go back to orignal and then went stainless.
Will see if i still have them if interested.
Rob
stephenh
#6 PostAuthor: stephenh » Thu Oct 13, 2011 1:01 pm
hi Rob yes i am very interested in the bolts if you still have them
regards steve
