Leaky frame
mikey
Leaky frame
#1 PostAuthor: mikey » Mon Oct 10, 2011 6:06 pm
As per the projects section i have started the rebuild of my ltd, anyway
had the frame sat on its rear end today and a considerable amount
of water ran out the seat rails, its a j type motor frame and am i right in saying i remember reading somewhere that j type frames collect
water in some area and rot from the inside out?
My concern is had a good look at it and it all looks very rusty round the side panel area and below that i would assume that when it goes for blasting that would show up any structual weakness?
#2 PostAuthor: Pigford » Mon Oct 10, 2011 6:12 pm
Water tends to collect right near the side stand - lower l/hand by foot rest :??
Taffus
#3 PostAuthor: Taffus » Mon Oct 10, 2011 6:34 pm
Didn't Ginger bear have a frame scrapped because of this? :?:
Mark Tiller
#4 PostAuthor: Mark Tiller » Mon Oct 10, 2011 6:47 pm
Have a tap arond the affected areas with a screwwdriver, a change in the sound might give a clue as to any weakness..
Dry out and fill with wayoyl or similar
07962421462
#5 PostAuthor: PAULJAC47 » Mon Oct 10, 2011 6:59 pm
Yep Mikey fraid this is a common prob check were the sidestand bracket is welded to the frame if in doubt get a gusset welded alongside to give extra strength...Paul J
mikey
#6 PostAuthor: mikey » Mon Oct 10, 2011 8:25 pm
Ok cheers guys let you know how it goes
#7 PostAuthor: Ginger Bear » Wed Oct 12, 2011 6:37 pm
Here ya go Mikey..........
......... This is what it shouldn't look like. :shock:
# 104
Z1parR
#8 PostAuthor: Z1parR » Wed Oct 12, 2011 6:42 pm
That should cheer him up Steve :lol: :lol:
0172 . Geoff Parr
mikey
#9 PostAuthor: mikey » Wed Oct 12, 2011 10:24 pm
Mine aint like that steve thank goodness
steve.w
#10 PostAuthor: steve.w » Thu Oct 13, 2011 6:03 pm
Ginger Bear wrote:Here ya go Mikey..........
easy fix steve cut out the bad n weld in some new :roll:
