Z1100R Bore increase.
yox
#1 PostAuthor: yox » Tue May 15, 2007 10:47 am
Hi,
going to bore my z11r out to 1170,
1st question, what carbs work best?
2nd question, where's the best place to get the piston's from?
many thanks.
#2 PostAuthor: Pigford » Tue May 15, 2007 5:23 pm
Best carbs, for availability, tuning & cost are probably Mikuni RS36 or 38, with large conical K&N's :wink: try eBay :shock:
Jeff at Zenterprises (see links page) is ace, and US dollar exchange rate is very good at moment :D
london calling
#3 PostAuthor: london calling » Tue May 15, 2007 5:26 pm
Hi Yox,my 1170's run Mikuni RS36mm flatslides and this appears to be the optium size carb for the 1170 bore.
A cheaper alternative would be a set of slabside GSXR flatslides with the bored out inner to take them out to 33mm.
For the Wiseco kit either Jeff Saunders at Z1 Enterprises in the U.S.A. there is a link to Jeff in the links section.
For the best U.K. prices speak to GREMLIN @ Gremlin Racetech
Tel/Fax:01785 220899
Mob:07950 876368
gremlinracing99@aol.com
www.gremlinracing.co.uk
My last Wiseco kit came with a 2 piece Cometic head gasket but it was only 74mm diameter.You're best off with a 1 piece copper Cometic head gasket anyways.The Cometic website will list the part number you need.
Make sure the Wiseco kit is for the 18mm pins as per GPz uni-trak a.k.a. ZX1100 and not the J type with 17mm pins.
When you get your block bored it will require several passes as you're going from 72.5mm upto 75mm.
:D :D
Jack
uk kev
#4 PostAuthor: uk kev » Tue May 15, 2007 6:14 pm
Jack the gremlins have got in the Gremlin links! as in they don't work?
london calling
#5 PostAuthor: london calling » Tue May 15, 2007 7:13 pm
Sorry Kev.His email and phone numbers are spot on.
harrisxr69 is his ebay name :D
You should be able to get him via a google search.
Jack
yox
#6 PostAuthor: yox » Wed May 16, 2007 10:58 am
Cheers for the info guys, I'm probably gonna strip the motor right down cos the paint is peeling off so will be an ongoing project this year. How do you post pics on here, i have photobucket. Wouldn't mind seeing yours as well(in a strictly motocycle way :shock: )
#7 PostAuthor: Pigford » Wed May 16, 2007 5:36 pm
Yox, to post photos from photobucket, just copy the IMG CODE bit :!:
Get posting mate :wink:
yox
#8 PostAuthor: yox » Wed May 16, 2007 8:37 pm
there, hope that works
blue one is a zrx400, between me and josie we have 2 11zrx, 400 zrx, zx6r and of course a z1100r. Selling the 6 and 4 to have a more managable 3 :shock:
