Carburettors ? is there a plumber in the house?
1340fxd
#1 PostAuthor: 1340fxd » Sat May 19, 2007 6:19 pm
My 1978 Z1000, from left to right (looking forward), carburettor 1 has no air vent pipe fitted to the carb body, carbs 2 & 4 have rubber pipes which run to a hole on the frame and carb 3 has a rubber pipe that goes to the vacuum feed on the fuel tap.
First question ? what do these air vents do?
Second question ? is it OK that they are left un-plugged?
Third question ? if I replace the fuel tap with a non-vacuum one, do I need to plug air vent 3 or leave it open like 2 & 4?
If anyone knows the answers, it would be appreciated.
:P
uk kev
Re: Carburettors ? is there a plumber in the house?
#2 PostAuthor: uk kev » Sat May 19, 2007 6:24 pm
Hopefully this should give you all you need to know....
http://www.wgcarbs.com/index.php?option=com_content&task=view&id=17&Itemid=32
1340fxd
#3 PostAuthor: 1340fxd » Sat May 19, 2007 7:39 pm
That is really helpful - many thanks
Rene
Users browsing this forum: Headspinning and 95 guests
