oil light
PaulMceleney
- Chunks
oil light
can anyone tell me why my oil light will not go out when the engine is started its not low on oil it on a z1000 cheers
as taffus said remove the wire from the oil pressure switch the light should go out. if not remove switch. clean + make sure the switch is not stuck in the closed position. make sure the wire is not shorted to earth. otherwise could be the oil pump pick up blocked with sludge + old remnants of gasket paper
PaulMceleney
- Chunks
