Garn 1 wrote:I have tried to have this done in Australia... With the answer from many companies, because they have had brake fluid in them they are very hard to anodise.
A member of this forum from New Zealand (Toy Collector) said he had success with black anodising.
I contacted him about an address .. He then seemed disinterested and said that I must be able to find an anodising company in Oz!
kas750 wrote:Posted on another forum by one of the triples boys from nz.....
Home anodising.....Its EASY..., and gives that brand new factory look.
Clean the part to be anodised.
In a plastic container, fill with a fairly strong solution of sulphuric acid.
Place a stainless steel or lead cathode plate at the bottom with a stainless wire attached.
Suspend the part above this on a stainless wire, they must not touch and pour in the acid so the part is covered.
Connect a battery charger to both stainless wires, POSITIVE to the work, NEGATIVE to the cathode plate.
After 30 minutes or so of fizzing, remove work and wash and dry it. Immerse in the dye for 15 to 20 minutes, remove and boil it in water for 20 minutes... this hardens and sets the surface.
Dyes are easily found under the DYLON home dye brand..used for dying wool and fabric. Food dye will also work. All colours are available and cheap.
This is less trouble with small parts and easier than painting. Gives a hard wearing surface, great for brake/clutch levers, pedals, brackets, even a whole engine cover.
Practice the process first on scrap aluminium parts to get the feel, much depends on acid strength, charger current etc, everything works, but times vary.
Users browsing this forum: wilsonsjw11 and 42 guests
