Taylor Leads - Coil End
njwmct
#1 PostAuthor: njwmct » Wed Dec 07, 2011 6:22 pm
Could anyone advise the correct method for crimping Taylor Leads at the coil end?
A photo of the correct end result would be great!
#2 PostAuthor: Rich » Wed Dec 07, 2011 6:37 pm
For Dyna coils: Just look at a car lead, you need to do the same sort of thing, I made a crimper by drilling through two bits of steel flat bar, bit of hacksaw work and filing. Then put them in the vice and squeeze up.
I'll send you a photo of it over the weekend.
Original Kawa coil leads are molded in and you won't fit Taylor leads to them easily.
njwmct
#3 PostAuthor: njwmct » Wed Dec 07, 2011 6:40 pm
Rich wrote:For Dyna coils: Just look at a car lead, you need to do the same sort of thing, I made a crimper by drilling through two bits of steel flat bar, bit of hacksaw work and filing. Then put them in the vice and squeeze up.
Thanks & yes it's for fitting to Dyna Coils
#4 PostAuthor: Pigford » Wed Dec 07, 2011 7:05 pm
The ends are a bit confusing - but the more solid end with the little hole is fitted to the lead - and the core wire can thread thru' the hole :wink:
Best to put the waterproof rubber on first though :??
