Z1100ST Resto +
Stick to it mate, it'll be well worth it.
The location dowel can be replaced and the ignition cover problem can be solved with some chemical metal.
The housing is also a cheap fix by someone, who knows how to weld ally.
All solvable, just takes some time.
Make sure, you sell that Unitrack head on ebay and be surprised how much it'll fetch... Germans are crazy about UT-heads.
Greg
Greg
Iain marshall
- RALPHARAMA
The alternator rotor was pretty tight, but all the bolts on this engine have been over tightened. Fortunately I have got a puller. I suppose it was too much to be hoped that the rotor wouldn't be fecked.
Clutch on the the face of it doesn't look too bad, but I'm not going to get too optimistic given the state of everything else.
Last job tonight was to take the sump off. There is some nasty looking staining and scrape marks on the inside of the oil filter chamber; god knows what that's a sign of. The oil that came out, when I drained it cold, was like black water! The bottom of the sump is really yuck.
The oil pump strainer has lots of aluminium swarf attached to it; not sure where it's from .... yet!
Yankie e-bay breakers not replied to my e-mail asking for a shipping price
Went to powder coaters today. Sadly when I got back I realised that the dumbos hadn't coated the back of the footrest hangers! Left them with the rear bevel box. The boss man is back at work now, so hopefully stuff will be done properly from now on.
Ralph Ferrand
I would love to say, that sump doesn't look that bad, if it wasn't for the swarf. But don't worry too much about the black goo, that can happen if your bike is due for an oil change and is parked up for a week or two and the black debris will start to settle down...
The ally has to come from somewhere though...
- RALPHARAMA
Bit more positive tonight
Cleaned up the sump tonight; inside and out
The rear bevel case came back from the powder coaters this afternoon.
Here's some of the other bits that came back before
Here's the clutch being degreased
I did managed to dig out another alternator casing from 'stock'; this one has suffered it's fair share of abuse, but nothing I shouldn't be able to sort out. Yes those were screws in another life
Hopefully I'll do some more over the weekend
Ralph Ferrand
- RALPHARAMA
I've fitted dozens and dozens of WMD's stainless pistons and have never had a problem. Tourmax used to be distributed by HiLevel, but they very often supply shit Chinese jobs now, so I have found that WMD's gear is far more reliable. I'd much rather have the corrosion resistance of stainless that plated mild steel. If Wemoto (retail arm of WMD) have sent you some dodgy pistons ring them up and I'm sure that they'll replace them. I've always had excellent service from them.
Ralph Ferrand
well I had a batch of 4 pistons ordered and 3 of them were ranging from 3/10th mm undersize to 2/10th mm oversize and a runout in about the same region.
I can only send the last set back, as I did machine all others (except for the undersize piston) to fit.
Greg
Greg
- RALPHARAMA
nanno wrote:well I had a batch of 4 pistons ordered and 3 of them were ranging from 3/10th mm undersize to 2/10th mm oversize and a runout in about the same region.
Greg
That's pretty shit. I must admit that I haven't measured any I have received, but given that they have always been a nice snug fit in the calipers, I have never had a reason to. A twenty thou variation is pretty awful.
I've often considered making my own pistons out of 316, but the 'hollowing out' bit is way too much hassle on a snotty little lathe like mine
Ralph Ferrand
