GPz1100B1 clutch lever problem
BRIAN S
#1 PostAuthor: BRIAN S » Wed Dec 21, 2011 9:35 pm
I have been trying to get an original clutch lever to replace the none original one on my GPz1100B1,i bought one of ebay nos with the part number 46092-1020 Number listed for my bike,only to find it did not fit,and no flat bit to work the clutch switch :?: i have since looked at lots on ebay listed as for my bike but with no part to work the switch,also the one i got did not fit in the holder(to big) i just dont get it :?: The bike is an import but iam sure parts are the same as uk,had no problem with the brake lever.But not sure if uk bike is fitted with a clutch switch :?: As i say all the ones i have seen a photo of on ebay have no provision for this but say they are for my bike,and part number is the one in my original parts book.Anyone have any idea what the problem is :?: Cheers Brian
GPz1100B1
Padders
#2 PostAuthor: Padders » Wed Dec 21, 2011 10:04 pm
Brian part number 46092-1020 is correct for a B1 for the UK and for Europe. It fits both types those with the clutch cut out switch as a seprate part and those with the cut out switch as part of the left hand housing assembly. This model does not have a flat section on the clutch lever to work the switch. Have you got the correct holder part number 13091-1046.
#3 PostAuthor: z1bman » Wed Dec 21, 2011 10:26 pm
does it look like this. if so you have the wrong clutch lever + bracket fitted for a gpz1100 b1
http://www.ebay.co.uk/itm/Kawasaki-ZX60 ... 867wt_1082
http://www.ebay.co.uk/itm/Kawasaki-GT75 ... 907wt_1037
BRIAN S
#4 PostAuthor: BRIAN S » Thu Dec 22, 2011 10:04 pm
Cheers for the help guys,looks like the problem must be the holder.Thanks for the part number Ian.Yes z1bman the one have fitted just now looks like the ones in the the links you give me.so looks like i will be looking for a new holder. Cheers Brian
GPz1100B1
#5 PostAuthor: z1bman » Thu Dec 22, 2011 10:29 pm
might need painting black but this is the correct lever + mount bracket
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 866wt_1037
BRIAN S
#6 PostAuthor: BRIAN S » Thu Dec 22, 2011 11:06 pm
z1bman wrote:might need painting black but this is the correct lever + mount bracket
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... #ht_866wt_
1037
Cheers for that z1bman just bought it :up
GPz1100B1
Users browsing this forum: Bing [Bot] and 74 guests
