Wiring loom help
kwak
Wiring loom help
#1 PostAuthor: kwak » Thu Dec 22, 2011 9:44 pm
hi all
at the moment i am going to be putting my gpz A2 engine in my Z9 frame till my Z1 engine finished it will be running full dyna 2000 ignition the problem is what wiring loom do i get or can some one make me one up ?
Beastie
#2 PostAuthor: Beastie » Thu Dec 22, 2011 10:38 pm
Andy, I have an Z900A4 and I bought a "new" wiring loom from ZPower I think I paid about £165, earlier this year I was speaking to a guy with an early '90's Bimota with a Ducati Superlight engine, he had contacted one of these guys who advertises regularly in the bike press - he wanted £1000 to re-wire his bike :shock: :shock: :shock:
£165 is a bargain!
Beastie
kwak
#3 PostAuthor: kwak » Thu Dec 22, 2011 10:40 pm
Beastie wrote:Andy, I have an Z900A4 and I bought a "new" wiring loom from I think I paid about £165, earlier this year I was speaking to a guy with an early '90's Bimota with a Superlight engine, he had contacted one of these guys who advertises regularly in the bike press - he wanted £1000 to re-wire his bike :shock: :shock: :shock:
£165 is a bargain!
That is good price but the problem is will i need to buy 2 different looms one for the GPZ and one for the Z900/100 when i go to change engine back over
Rhencullen
Re: Wiring loom help
#4 PostAuthor: Rhencullen » Thu Dec 22, 2011 11:06 pm
andy.jc wrote:hi all
Will it fit and mount ok :?: The 900R frame is very different to a Z900 - in fact, the engine is part of the frame on a 900R.
kwak
#5 PostAuthor: kwak » Thu Dec 22, 2011 11:18 pm
It is not a 900R frame as i stated
it is a Z900 1976 frame which i am putting my gpz1100 A2 engine in till i get work finished on my Z9 engine will i need 2 different looms or can i use the Z900 loom as i will be fitting dyna 2000 full ignition
thanks
Rhencullen
#6 PostAuthor: Rhencullen » Thu Dec 22, 2011 11:23 pm
Sorry - thought you meant you were trying to put an A2 GPZ900R engine in the frame.
kwak
#7 PostAuthor: kwak » Thu Dec 22, 2011 11:30 pm
Rhencullen wrote:Sorry - thought you meant you were trying to put an A2 GPZ900R engine in the frame.
That is ok not a problem, thanks for trying to help
Big Fluff
#8 PostAuthor: Big Fluff » Fri Dec 23, 2011 10:12 am
Andy, where do you live?
I've wired 100's of bikes over the years and specialize in Kawasaki.
Will
#9 PostAuthor: PAULJAC47 » Fri Dec 23, 2011 2:58 pm
Beastie wrote:Andy, I have an Z900A4 and I bought a "new" wiring loom from ZPower I think I paid about £165, earlier this year I was speaking to a guy with an early '90's Bimota with a Ducati Superlight engine, he had contacted one of these guys who advertises regularly in the bike press - he wanted £1000 to re-wire his bike :shock: :shock: :shock:
£165 is a bargain!
Ferret by any chance?
martinz1000r
#10 PostAuthor: martinz1000r » Fri Dec 23, 2011 3:13 pm
Ferret quoted me £45 per hour to rewire my Z1000R and told me it could be 2 days work so I would not see much change out of £1000. I'm sure he is very good but I could not afford that. I bought a 2nd hand loom from J Browse and replaced all the connectors from either cojaycat on eBay or Vehicle wiring Products. My switchgear is a combination of Yam R1 and ZX7R. Blow up a copy of a proper wiring diagram and laminate and away you go. It took a while to do properly but the job is really neat, everything works and I got rid of loads of redundant wires to switches you probably don't want. Go for it!
#11 PostAuthor: Rich » Fri Dec 23, 2011 7:59 pm
Look at the engine mounts before you go any further.
#12 PostAuthor: ADRIAN H » Fri Dec 23, 2011 8:44 pm
Rich wrote:Look at the engine mounts before you go any further.
Agree engine mounts are different.
Beastie
#13 PostAuthor: Beastie » Fri Dec 23, 2011 9:30 pm
PAULJAC47 Yes it was Ferret apparently, reding the reviews in magazines I'm sure he does a good job and he does come to you, but.....
Beastie
neilbarrett
#14 PostAuthor: neilbarrett » Sat Dec 24, 2011 9:16 pm
if your using a dyna 2000 ignition,i carnt see why you carnt use the standrd 900 loom,charging system might be differnt but sure you get round it
