Any advice appreciated
Stator housing oil leak
- Tonka
I have an oil leak coming from the stator housing on my Z1a where the wires come out and wondered what the most effective solution or sealant Is to stop it - fed up of getting my boot covered in oil
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Neil Best fix is a new seal but i have had some success with cleaning with brake cleaner and RTV silicone,Cheers Paul J
- Tonka
Not done anything to it as yet. I was told just fitting a new seal without using some sort of sealant will not stop it leaking. Only want to fix it once
Possibly worth 'roughing up' both rubber & casing to provide a good 'key'.
I have used Threebond 1211 in the past, with exceptional results. The important thing is to remove all oil/grease from the surfaces to be sealed, and as already said, brake cleaner is a good way to do this.
Threebond 1211, ain't the cheapest. But your Zed deserves the best. Do it properly & you'll only do it once.
http://www.ebay.co.uk/itm/Threebond-121 ... 563722ce95
Might be worth reading this..... http://www.z1ownersclub.co.uk/forum/vie ... 1&start=15
- z1000puddin
As others have said, the real key to getting an effective seal is to make sure that the area, rubber seal and wires are completely degreased. I personally have used cellulose thinners to degrease, then used black silicone sealant- ensure that when applying sealant you get it all around the wires. I usually cut back the braided outer of the wires to expose the plastic insulation , this gives better results too.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
