the z900 i bought recently has a tank from a z1000a2 i think, which has a fuel tap with the vacuum outlet. this is a bit tempremental so want to change it for a conventional tap, have seen an adapter on z1ent but needs a new pingel with a male thread to screw into the adapter plate, on ebay.com there is an adapter plate that uses the female fuel tap adapter but comes with a fuel tap which i do not need,
http://www.ebay.com/itm/PINGEL-Petcock- ... 27bfe72af2
is an adapter like this available anywhere to use the normal fuel tap?
fuel tap adapter plate
http://www.pingelonline.com/powerflo_adapter_plates.htm
would be worth giving ray debben a call as he has the complete pingel tap with a adaptor of your choice. just ask if he can supply the adaptor plate separate
www.debben.co.uk or PM Steve who posts on here as debben1
Ginger Bear wrote:www.debben.co.uk or PM Steve who posts on here as debben1
Beat me to it. Debben performance, ringwood - normally has them in stock.
