Z1000 / KZ1000 twin front brakes
1340fxd
#1 PostAuthor: 1340fxd » Wed May 30, 2007 10:02 pm
I have a US model KZ1000 with single front disc and want to convert it to twin disc (parts wanted - see that section)
Is the twin disc set-up master cylinder the same as the single disc master cylinder :?:
#2 PostAuthor: chrisNI » Wed May 30, 2007 10:22 pm
You need a 5/8 for two discs - the single one is 3/8. It says underneath what it is.
bunnysZ
Granny Magnet
#3 PostAuthor: bunnysZ » Wed May 30, 2007 10:49 pm
recently upgraded my kz1000,
some of the kz had the 5/8 cylinders on single discs for owners to upgrade if required,
also if you buy a new/secondhand disc make sure its the same thickness as the one you have on at the moment, best if you can buy a complete twin set up off a bike.
while doing it put on braided hoses
think there is a set on usa ebay at the moment, just the time and postage is a problem
1340fxd
Thanks - very useful
#4 PostAuthor: 1340fxd » Thu May 31, 2007 4:54 pm
Thanks for this information. I have sourced two callipers and a splitter and possibly also two discs so getting there.
I have looked underneath the master cylinder and all it says is PAN TOKICO and then there is the number 14 - no sign of 5/8 or 3/8 - is there another wau to tell if my master is compatible with thetwin setup?
Also is this conversion really worth doing as I understand the brakes are not the best in the world either way - is there a noticeable difference?
Keith
#5 PostAuthor: Keith » Thu May 31, 2007 5:36 pm
think you'll find the reservouir is phsically taller for the twin disc - checked and it's 3" from top to bottom - the reservouir that is! :oops:
find the 2 discs help but back is pretty dull
i suppose, as any good lady would say, 2 upfront are better than 1 and 1 is better than none :)
Re: Thanks - very useful
#6 PostAuthor: Rich » Thu May 31, 2007 8:37 pm
1340fxd wrote:Thanks for this information. I have sourced two callipers and a splitter and possibly also two discs so getting there.
That'll be a 14mm one - they work on 5/8 and 14mm bore size now. You'll be better off getting a 5/8 one for twin disks
Magik
#7 PostAuthor: Magik » Fri Jun 01, 2007 8:15 am
Rich, I've got two discs you're welcome to (freebie) O/S disc is 6mm N/S disc is 4mm. they're useable but not purfect if you want them? You may be able to get them re faced?
