Ears
irhobotolo
Ears
#1 PostAuthor: irhobotolo » Fri Feb 10, 2012 6:16 pm
I am looking for a pair of Headlight brackets / Fork ears for a 73 Z1 . The ones with the blended seams. Preferably genuine parts. No problem if they need rechrome as long as they are straight and not damaged.
Failing that .... :D Does anyone have experience with the following parts. Are they accurate reproductions and is the quality similar to Kawa originals ???
http://www.ebay.co.uk/itm/160730125342? ... 1423.l2649
http://www.ebay.co.uk/itm/330469407733? ... 1423.l2649
000zeds
#2 PostAuthor: 000zeds » Fri Feb 10, 2012 9:35 pm
Z-Power have them £49.99 for pair.
https://www.z-power.co.uk/merchantmanag ... ucts_id=99
Zeds-R-Us
pertonpc
#3 PostAuthor: pertonpc » Fri Feb 10, 2012 10:23 pm
Hi Steve
If its anything like a Z1-b then the genuine ears will have an extra inner metal flap where the indicator stem goes through.
Original had one outer and two inner and repro had only one of each
Got a pic of what I mean if you want it emailing.
Ask for a pic of the inside of the new ears if you have an original to compare with.
baz
#4 PostAuthor: baz » Sat Feb 11, 2012 8:50 am
steve, the ones that z power do are a perfect copy of the 73 ears with smooth seams and the chromes very good too, well worth the money :D
Users browsing this forum: baz, Google [Bot] and 25 guests
