fitting comtec head gasket
knut
#1 PostAuthor: knut » Fri Feb 17, 2012 10:09 pm
hi guys,
quick question, when replacing old 2 part head gasket with a new one piece head gasket would one refit the orings under it as well ?
bike is gpz1100 b1 ,
thanks mick
#2 PostAuthor: Rich » Sat Feb 18, 2012 8:08 am
No fill o-ring groove with RTV and let it go off. Trim excess above block surface off then put a light smear onto each side of the gasket instead of the o-ring before fitting.
This way you don't have to get the excess out of the tunnel after fitting.
#3 PostAuthor: paul doran » Sat Feb 18, 2012 2:16 pm
Knut your memory is going
I already told You all that before when I advised you to use a one piece gasket
must be Your age catching up on You :lol: :lol:
