Carbs
jonhunt
Carbs
#1 PostAuthor: jonhunt » Mon Mar 05, 2012 10:12 pm
Where do you measure the 28 mm vs 26mm on the carbs I take it that its on the engine side of the carb block
CAT3
#2 PostAuthor: CAT3 » Mon Mar 05, 2012 11:44 pm
I would think it's where the main jet is positioned, near the centre of the carb. No doubt someone knows for certain.
sweptail
Re: Carbs
#3 PostAuthor: sweptail » Mon Mar 05, 2012 11:58 pm
jonhunt wrote:Where do you measure the 28 mm vs 26mm on the carbs I take it that its on the engine side of the carb block
correct
#4 PostAuthor: Pigford » Tue Mar 06, 2012 7:45 am
Its always the NARROWEST part of the venturi (carb throat) :wink:
