Brakes stuck
Brakes stuck
Spent all day inspecting the brake calipers and renewing brake fluid in my Z900A4, only to find that when i put the caliper i had dislodged a seal and air was getting in. Anyway replaced the seal and bled brakes in under an hour, however, the brakes are now stuck on solid - the piston won't retract!  Before I take a hammer to it tomorrow any ideas what the problem may be?
Rob
						Rob
Just my 2 cents worth but I think your piston will be jammed by the seal, either the new seals are shite, they are not sitting right or there is some build up of possibly corrosion or some old deposit in the seal groove that is pushing the seal out of position and against the piston in such a way as to prevent it moving back.
						Either the piston is stuck in the caliper (was it the original piston or a replacement ?) or the two bolts that the caliper mounting bracket slides along are stuck.
It's more likely the problem is with the caliper mounting bracket & bolts, which may just require stripping, cleaning & re-greasing.
Another possibility is that one or both of the bolts could be bent slightly & not allowing the caliper mounting bracket to move back once pressure on the psiton is released.
- z1000puddin
Users browsing this forum: shorty and 50 guests
