Removing a Zed Clutch - in situ?
Am I right in thinking, the only way to remove the clutch basket on me Z1000A2, is to strip the engine! I seem to remember last time I was rummaging around that bit, it looked impossible to get the clutch out without splitting the engine
Agree with Rich... "Cases must be split to remove the clutch basket". I have heard of a mod, where a minimum amount of alloy is removed from the cases to allow removal to be performed without splitting the cases. It is auguable whether it would be considered a necessary or desirable mod, mainly because the cases have to be split to do the mod!
It's good to know that you can leave the crank-shaft, head etc. undisturbed during this basket removal process.
RegardZ
RegardZ
Hi Steve, yeah, all plates seem OK, no ridges/burrs on basket tangs
Its when pulling away on low revs & throttle, it sometimes judders and seems to slip a bit. But clutch don't usually slip other times, like full throttle
Also a bit rattly sounding when toodling along in high gears at low speed, when opening throttle (too lazy to change down)
Users browsing this forum: Headspinning and 104 guests
