Battery Drain
DavidZ1R
Battery Drain
#1 PostAuthor: DavidZ1R » Tue Mar 27, 2012 7:50 pm
My little project, having fun with, put a new battery on last week, trickle charged it to full charge, all ok, notice that after a few days standing most charge dropped down, nothing switched on the bike so any ideas what could be draining it? :?:
#2 PostAuthor: PAULJAC47 » Tue Mar 27, 2012 8:13 pm
If you have a multimeter connect it in series on the dc amps range in the battery positive line.ie disconnect the battery positive connect it to the common on the meter and connect the 10a connection on the meter to the battery postive,if you have a reading with all electrics and switches off this will indicate your current drain!it is is then a case of tracing the wiring etc and disconnecting one piece of kit at a time till the drain ceases,of course it may be just you have a sulfated battery if it has been standind try disconnecting the battery and see if it still loses its charge. a good battery should be 2.2 volts per cell ie 6x2.2=13.2....Hope this helps Paul J
DavidZ1R
#3 PostAuthor: DavidZ1R » Sun Apr 01, 2012 2:58 pm
If I had a multi meter I will try, there are a few on the market can anyone recommend one that is cheap enough to buy and does the trick?
#4 PostAuthor: PAULJAC47 » Sun Apr 01, 2012 6:11 pm
http://www.ebay.co.uk/itm/Digital-Multi ... 1c2549dca0
This is cheap but will do for what you need mate! Paul J
tlc
#5 PostAuthor: tlc » Sun Apr 01, 2012 7:16 pm
Vehicle Wiring Products do a superb meter that includes a 10amp fused setting.
I use mine at work and in conjunction with a probe tester is all you will ever need.
http://www.vehicle-wiring-products.eu/V ... /79860.jpg
#6 PostAuthor: PAULJAC47 » Mon Apr 02, 2012 6:51 pm
Chris ,do you know anyone who needs their probe testing??? :lol:
DavidZ1R
#7 PostAuthor: DavidZ1R » Wed Apr 04, 2012 3:25 pm
Not had my probe tested yet, but getting to that age, got my multimeter :D looks like a duff cell on the battery, only reading 10.38 volts 12 hours after a full charge, cheers pauljac47 and tlc.
