front end
sme
front end
#1 PostAuthor: sme » Thu Feb 23, 2012 12:20 pm
i am looking for a complete front end to fit a
z1000j
rwu forks, 3 spoke wheel
or what bike model is easiest to fit so i can keep an eye out for one.
thanks
big green bus
#2 PostAuthor: big green bus » Thu Feb 23, 2012 4:43 pm
750 zephyr ones fit in bearings are the same (41). 1200 bandit or FZR1000 forks (43) are the ones I prefer because of the length, but you need to get a bearing stem made or pressed in (my mate can make them if you get stuck) becareful not to get forks too short 29" is about as short as you can get away with, using a harris pipe etc. Most Kawasaki ones tend to be too short, but other members might know otherwise.
jovin04
Re-Front end
#3 PostAuthor: jovin04 » Tue Feb 28, 2012 9:26 am
Hi i have an early gpz1100 front end if your intrested
Cheers Vince
sme
#4 PostAuthor: sme » Wed Mar 28, 2012 1:07 pm
i am now needing a modern front end to fit a gpz1100
3 spoke 17" wheel set up
anybody got one to sell?
#5 PostAuthor: Pigford » Wed Mar 28, 2012 5:17 pm
I got a v.g.c Bandit 1200 front end :wink:
garyd
#6 PostAuthor: garyd » Wed Mar 28, 2012 5:44 pm
If sme doesn't want it...shoot me a PM :wink:
Gus
#7 PostAuthor: Gus » Wed Mar 28, 2012 6:20 pm
garyd wrote:If sme doesn't want it...shoot me a PM :wink:
Will this one do? :lol:
"Set the GRINDER on it"
sme
#8 PostAuthor: sme » Wed Mar 28, 2012 7:34 pm
i asked pigford before but no reply.
pm thanks
750steve
#9 PostAuthor: 750steve » Wed Mar 28, 2012 9:05 pm
Kawasaki ER6 forks are 41mm as well, RWU too & uses a 17mm axle just incase this info is usefull to anyone. You'll probably need to press out its stem & use the original one though along with a bushing to adapt the 2.
I'm going to be putting that front end onto a Z650 after i finish the current project.
#10 PostAuthor: Pigford » Thu Mar 29, 2012 6:43 am
PM sent :wink:
Users browsing this forum: Google [Bot] and 11 guests
