long speedo cable
oldzed
long speedo cable
#1 PostAuthor: oldzed » Wed Mar 28, 2012 10:05 am
Wondering if the gurus can help
Does anyone know which (If any) model has the longest speedo cable?
I know I can get a cable extension but would prefer a one piece cable
For a z1000st
Regards
Craig
RGH
#2 PostAuthor: RGH » Wed Mar 28, 2012 4:16 pm
Check Z1 Enterprises site, you have to check each model and it lists the length of all cables.
Big Fluff
#3 PostAuthor: Big Fluff » Wed Mar 28, 2012 5:31 pm
You could try Venhill cables, they can make whatever length cable you want!
Garn 1
#4 PostAuthor: Garn 1 » Thu Mar 29, 2012 2:19 pm
I had to purchase a longer speedo cable to get around rear mounted callipers on a Z1. I found the Z1000-2A fitted perfectly, as this model had the rear mounted callipers.
I do know that the Rickman has a super long speedo cable, as its "takes-off" is as at the rear wheel.
oldzed
#5 PostAuthor: oldzed » Thu Mar 29, 2012 5:20 pm
thanks for the replys all.
Will order a couple from Z1 Enterprises
