helicoil kits.
andyb1962
helicoil kits.
#1 PostAuthor: andyb1962 » Fri Apr 06, 2012 1:33 pm
i have my 3 number spark plug thread well worn. it is still servicable though.
i am going to chase the thread with a grease covered tap to try to improve things. Question is, Can i fit a thread insert without taking the head off and all the filings getting into the cylinder ?
Andy :wink:
#2 PostAuthor: Ginger Bear » Fri Apr 06, 2012 1:52 pm
I've chased spark plug threads & regretted it. :shock:
Just made the plug really 'loose'.
My suggestion would be to live with it, or have the head off & have the job done properly.
# 104
#3 PostAuthor: kev edwards » Fri Apr 06, 2012 1:57 pm
Like Gb says live with it until absolutely needed or take the head off and have it done properly.
andyb1962
#4 PostAuthor: andyb1962 » Fri Apr 06, 2012 2:36 pm
Sounds good advice guys
ill live with it for now
Andy :wink:
jimmock
#5 PostAuthor: jimmock » Fri Apr 06, 2012 2:51 pm
Ginger Bear wrote:I've chased spark plug threads & regretted it. :shock:
When I was at school, I chased a few girls.
But never a spark plug thread??
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
zman
#6 PostAuthor: zman » Fri Apr 06, 2012 4:00 pm
I had one done by a local engine shop.£20 a good job
keep thoses wheels turning
andyb1962
Re: ===========
#7 PostAuthor: andyb1962 » Fri Apr 06, 2012 4:42 pm
zman wrote:I had one done by a local engine shop.£20 a good job
that sounds cheap! how did they do it for that? :?:
Andy :wink:
#8 PostAuthor: PAULJAC47 » Fri Apr 06, 2012 6:03 pm
There is a new tool on the market that you lower through the spark plug hole it then expands and you thread from the combustion chamber outwards,sealy tools www.sealytools.co.uk
andyb1962
#9 PostAuthor: andyb1962 » Fri Apr 06, 2012 6:21 pm
PAULJAC47 wrote:There is a new tool on the market that you lower through the spark plug hole it then expands and you thread from the combustion chamber outwards,sealy tools www.sealytools.co.uk
http://www.sealey.co.uk/PLPageBuilder.a ... ctid=15528
this looks like the tool . has anyone tried one?
Andy :wink:
#10 PostAuthor: PAULJAC47 » Fri Apr 06, 2012 6:44 pm
Thats the one Andy got to be better than the grease trick.for that kind of cash its worth a stab ...Cheers Paul J
kz900B1
#11 PostAuthor: kz900B1 » Mon May 14, 2012 11:51 am
Hi Andy, Did you give it a try ?.One of the plug threads in mine has some damaged threads :cry:
colinKZ900B1
ruffle
#12 PostAuthor: ruffle » Mon May 14, 2012 2:34 pm
I can't see how this works.
I could see it being useful to clean up a cross threaded plug hole but chasing the thread will removed material which won't make the plug a better fit.
z1000puddin
#13 PostAuthor: z1000puddin » Mon May 14, 2012 6:10 pm
Do it right & whip the head off.
I used these http://www.timesert.com/AFTER I tried the grease way.
I will try & post a pic of my valve once it chewed up a small fragment that the grease did not catch. (Not a pretty sight)
Zed til Dead
Charlie
#14 PostAuthor: Charlie » Tue May 15, 2012 7:30 am
Andy - I have a spark plug thread chaser tool very similar to that mate. ( same thing but a different make)
I have never used it cos I've not had cause to but if you wanted to try it instead of buying one you are welcome to borrow it.
I am pretty sure I also have some spark plug helicoils too if you need them
I am just off junction 36 if that is of use to ya ?.
Users browsing this forum: Stugill and 55 guests
