Removing kickstarter from a Z1000Mk.II
Viktor Larsson
#1 PostAuthor: Viktor Larsson » Sun Apr 15, 2012 1:28 pm
How do I go about doing this? I don't have a manual for the bike so I don't know the proper procedure.
Do I remove the big spring that's behind the cover and then the plastic bushing and axle?
If anyone knows the right way to do it or has pictures of the procedure, please share. :oops:
There's no replacement for displacement.
Viktor Larsson
#2 PostAuthor: Viktor Larsson » Sun Apr 15, 2012 1:48 pm
Thanks for the move. Forgot all about the technical forums. :??
#3 PostAuthor: chrisu » Sun Apr 15, 2012 1:52 pm
if you mean the whole kickstarter mechanism not just the kickstart arm then it an engine out and cases split job. You can leave the top end in place.
if you don't want it to look like it has a kickstart shaft you could get a Z1R rubber cap for the spline.
not sure I've understood the question so if not please can you clarify
#4 PostAuthor: z1bman » Sun Apr 15, 2012 1:53 pm
to remove the kick start shaft you will need to split the crank cases
Viktor Larsson
#5 PostAuthor: Viktor Larsson » Sun Apr 15, 2012 1:58 pm
Thanks guys. Guess I'll just put a cover over the splines.
Question answered. :)
#6 PostAuthor: chrisu » Sun Apr 15, 2012 2:06 pm
#7 PostAuthor: Rich » Sun Apr 15, 2012 7:01 pm
Z1R top hat cover will smarten it up or as said before split the cases.
gray
#8 PostAuthor: gray » Mon Apr 16, 2012 9:09 pm
I seem to remember in an article in the 80s someone used a lid from a bottle of Brut 33 to cover the splines - a nice chromed "period mod" if you will?
Not that i've got any left over from then I hasten to add
gray
#9 PostAuthor: Ginger Bear » Tue Apr 17, 2012 4:44 pm
# 104
#10 PostAuthor: chrisu » Tue Apr 17, 2012 6:34 pm
That's the one
Big Fluff
#11 PostAuthor: Big Fluff » Thu Apr 19, 2012 12:27 pm
Viktor Larsson wrote:Thanks guys. Guess I'll just put a cover over the splines.
Victor.
17mm Chrome wheel nut covers are a perfect 'knock-on' fit over the shaft end.
I have one fitted on the Saxon.
I've lots spare, if you want one PM me your address and I'll post one out.
Will
Old pic shown here.
Users browsing this forum: Bing [Bot] and 58 guests
