Anyone got any tips for improving the throttle action on a Z1000 MKII (Mikuni VM28SS carbs)?.
I know that this is how they are / were but the current throttle pull is quite heavy.
Also the throttle action is quite slow - feels like you are winding it round the world!
Anyone managed to improve theirs?
Throttle action
First of all you must ensure the correct path for your cable run.
For lubrication I use one of these little gems.
http://www.wemoto.com/parts/picture/BI-CLBBU/
I clean them first with brake cleaner until they run clear. Allow it to dry and then use a lubricant of some sort. I always used to use WD40 on my off roaders but that must be done every ride. Nowadays I use a product called Lubrice from Autosmart. Basically it is a light grease that goes in liquid form and dries off a little.
I am now famous for my smooth action
A 3mm spacer below the cables will quicken it up nicely, I now have 90' of movement between off and full throttle. If you have access to a lathe they are easy to make out of some nylon. Make it so it fits in as per:
http://www.ebay.co.uk/itm/Mk1-QUICK-ACT ... 5649b298f1
You will probably have to alter the cables outer to inner length to allow for this.
Users browsing this forum: Bing [Bot] and 58 guests
