Cleaning an engine without stripping
Andy M
#1 PostAuthor: Andy M » Fri Apr 20, 2012 9:24 am
I have seen threads on this but can't find much on it.
What is a good way to clean an engine without stripping it, I am looking at stripping the A4 getting the frame coated and doing a general tidy up, not a resto so not going overboard.
Soda / aqua blasting ?? what works?? Thanks in advance.... :wink:
tedsonthezed
#2 PostAuthor: tedsonthezed » Fri Apr 20, 2012 9:38 am
Ok, I'm no expert but did get some soda blasting done last year. Brilliant for paint and crud removal and will not damage the engine - the guy who did it said how he had seen an Aston Martin cylinder head blasted with the cams still in situ with no ill effects. Mmmmm.
But because it's so gentle on the metal, it's crap at getting rid of corrosion, which on a bare A4 engine, I'd guess you would have.
You want how much?
martinz1000r
#3 PostAuthor: martinz1000r » Fri Apr 20, 2012 11:21 am
here you go
http://www.z1ownersclub.co.uk/forum/vie ... ht=#160665
i actually ended up stripping as it was easier and as the bits come back i am really pleased that i took this route.
Would also add that if i had not had head stripped the f**ked valve guides would not have shown themselves resulting in doing the job twice
Z.O.A
#4 PostAuthor: Z.O.A » Fri Apr 20, 2012 12:50 pm
Soda does a great job, but as said before, it does not remove any of the oxidisation or corrosion, it can't do this because it's not an abrasive, I believe it works by the tiny particles actually exploding on impact with the surface and so the resulting energy only removes anything on the material that is'nt supposed to be there.
I soda blasted the head on my A4 and it came up great, however the rest of the casings were a different matter (not corroded as such but badly oxidised on the surface), I ended up buying fine glass bead and doing the entire engine, did a fantastic job and left a nice smooth finish.
Andy M
#5 PostAuthor: Andy M » Fri Apr 20, 2012 9:10 pm
This is the engine.. it may not need blasting, ??/
Viktor Larsson
#6 PostAuthor: Viktor Larsson » Fri Apr 20, 2012 9:34 pm
I'd just give it a good scrub with some degreaser, a hard brush and then paint it. Worked really good on mine. Looks better than new.
There's no replacement for displacement.
Zed man
#7 PostAuthor: Zed man » Fri Apr 20, 2012 11:09 pm
Andy M wrote:This is the engine.. it may not need blasting, ??/
Andy, I was thinking the same thing. As there's people with bikes, That's running fine, But could do with just a clean up. Polishing/soda blasting/ with the engine in situ.( still in the frame) But no one does it?
So need must, This is me, not right finished yet but soon.
FRAMES TOO
This is a Suzuki gt750j frame, and i have 3 to do, and might offer this service, but not just yet sorry. This cabinet is 6ft 2" tall. as i might spray this one, gloss black. to this finish, main stand. Image
Soda to this standard.
Still not finished, the workshop yet.
Z903
#8 PostAuthor: Z903 » Fri Apr 20, 2012 11:18 pm
Depends on how much time you care to put in to cleaning it up, versus how much money you want to spend cleaning it up?
I chose the the time method :lol: and spent quite a lot of it. All done with paint stripper and polishing. Maybe not as good as vapour blasting, but it can be done without pulling down your engine.
But you can go from this....
To this with a little effort, all in the comfort of your own home. :D
coldsummer
#9 PostAuthor: coldsummer » Fri Apr 20, 2012 11:34 pm
I really, really, couldn't be arsed.
Is Vic There
#10 PostAuthor: Is Vic There » Fri Apr 20, 2012 11:49 pm
This is my GPZ900A1 engine.
I stripped it with paint which basically did bugger all, then had it sode blasted, the problem with sode is it does leave a residual, then had it blasted with a special process http://www.wetblasting.net/ now its at the painters. The finish is fantastic.
RAYZ1
soda
#11 PostAuthor: RAYZ1 » Sat Apr 21, 2012 9:50 am
Z.O.A wrote:Soda does a great job, but as said before, it does not remove any of the oxidisation or corrosion, it can't do this because it's not an abrasive, I believe it .....bead and doing the entire engine, did a fantastic job and left a nice smooth finish.
I had a problem with it not removing corrosion until I managed to aquire a building contractors site compressor for a day - it removed corrosion and oxidation well. I soda blasted my gs750 engine and carbs complete and it worked a treat - I then stripped the top end and side cases off to apply the engine paint to the top end and top case
hillbilly
#12 PostAuthor: hillbilly » Sat Apr 21, 2012 9:56 am
fourth pic back,you might want to swap the inlet rubbers round. :lol:
Z903
#13 PostAuthor: Z903 » Sat Apr 21, 2012 12:50 pm
hillbilly wrote:fourth pic back,you might want to swap the inlet rubbers round. :lol:
:lol: had that comment before! If you look closely you'll also notice there are stainless discs covering the inlet holes behind those inlet rubbers, to keep the crud out of the engine. It was pure luck that I'd clamped them on this way at the time.
Andy M
#14 PostAuthor: Andy M » Sat Apr 21, 2012 2:47 pm
Z903, what did you use to get your engine so clean ?? :??
Z.O.A
#15 PostAuthor: Z.O.A » Sat Apr 21, 2012 5:15 pm
Plenty of options for doing it Andy and people will probably have pros and cons for each process, I have my own small rig for soda or hard media blasting, it was cheaper for me to buy all the gear than sending it off somewhere to someone I did'nt know, plus I can use it again and again.
There are more than likely a lot more options for you to get stuff done in the UK than over here in Ireland and at much more reasonable prices too.
Here are a couple of before and after shots of my motor, sealed it up and did it complete before strip down.
