Single Outlet Pingel Tap - Z1000
JohnC
#1 PostAuthor: JohnC » Sat Apr 21, 2012 2:15 pm
Does anyone have a single outlet Pingel Tap, or want to swap a single for a dual outlet. I've just realised the VM 29 Smoothbores I've bought only have a single fuel inlet.
martinz1000r
#2 PostAuthor: martinz1000r » Sat Apr 21, 2012 4:02 pm
i have same issue. Just block off one outlet with an allen bolt in a bit of pipe. Not very neat but see you through til a single comes up. :D :)
JohnC
#3 PostAuthor: JohnC » Sat Apr 21, 2012 4:20 pm
Cheers Martin, I was thinking of doing this or using a blanked off splitter which I have.
#4 PostAuthor: Pigford » Sat Apr 21, 2012 6:13 pm
John - is it an earl Z1000 - with a screw-on tap - or later 2xbolt type :?:
JohnC
#5 PostAuthor: JohnC » Sat Apr 21, 2012 9:27 pm
Screw on one P :)
#6 PostAuthor: Pigford » Sat Apr 21, 2012 9:36 pm
I got a new screw-on tap - similar to Pingel - but different :wink: Thems pretty good at half the cost....... let me know if you're interested :wink:
