Z1100r carb options
jules
Z1100r carb options
#1 PostAuthor: jules » Thu Apr 19, 2012 7:17 pm
Advice needed
Z1100r mikuni bs34 carbs should be fitted to my R,god knows what's on it but there c**p whatever they are! Whats a good alternative? gsxr 750 I belive is a good choice,what else? Or has anybody got a serviceable set of bs34's.
P.U.M
'78 z1000a2,'83 1000r,'76 Z900a4,07 gsxr1000k6,'01 bj250,'03 husky 450,'83 Z1170r Lawson.
london calling
#2 PostAuthor: london calling » Thu Apr 19, 2012 7:38 pm
Jules,can you post some pics of your carbs :?:
The choke/air filter side is the most important.
Also CV carbs work best with an airbox.
The 1000J,1000R2 and the 1100R all run BS34 carbs but there are slight differences between them.
The 1100R runs different jet sizes between the inner and outer cylinders as standard.
Some 750 models also run 34 mm Mikunis.
Jack
jules
#3 PostAuthor: jules » Thu Apr 19, 2012 8:57 pm
Will try and get some pictures on over the weekend
P.U.M
martinz1000r
#4 PostAuthor: martinz1000r » Fri Apr 20, 2012 8:20 am
If you need a different set of carbs I have a couple of sets that need to go. Opposite ends of spectrum in terms of cost. Cheap end set of GSXR flatslide CVs jetted and float adjusted for GPz1100 engine. Came off my Moto Martin. Will need a good clean.
If you have cash to splash I have a set of RS34 flatslides again jetted for 1100 engine. You will need new rubbers inlets from Debbens but they are the dogs bollox.
Will be putting both in for sale section over weekend
nanno
#5 PostAuthor: nanno » Fri Apr 20, 2012 12:57 pm
I can only second the RS34s... they are the dogs.
jules
#6 PostAuthor: jules » Fri Apr 20, 2012 1:51 pm
checking bank account now!!mmmm!! which ones i wonder?
P.U.M
jules
#7 PostAuthor: jules » Wed Apr 25, 2012 12:05 pm
Thanks Martinz1000r
Option B now fitted,will do a update in projects soon.
P.U.M
Users browsing this forum: Bing [Bot] and 57 guests
