retorquing cylinder head - torque settings?
Kernowbiker
#1 PostAuthor: Kernowbiker » Sat Jul 29, 2006 12:55 am
Just had engine majorly serviced by local mechanic, new rings, cam chain, cam chain rollers, head gasket, etc...and now, 1000 miles later the head gasket is weeping again. So was rocker cover gasket so checked rocker cover bolts and head bolts and found that several were quite easy to move. Gonna take tank off and retorque them all but dont have workshop manual to tell me order and torque settings for head. Can anyone tell me please? :-)
Jerry
President
President
#2 PostAuthor: Jerry » Sat Jul 29, 2006 11:58 am
Clymer manual states, head nuts - 30ft/lbs, end bolts ( by no 1&4 plugs) 8lb/ft, Cam cover bolts 11ft/lbs. If you tighten them to that now, I'd recheck them after you've run the bike 4/5 times or in 100 miles, whichever is first.
Kernowbiker
#3 PostAuthor: Kernowbiker » Sat Jul 29, 2006 1:05 pm
Thanks, will try that and keep an eye on it.
#4 PostAuthor: Rich » Sat Jul 29, 2006 6:27 pm
Tightening sequence :
exhaust
12 10 6 2 4 8
13 14
11 7 3 1 5 9
Inlet
Tighten NUTS to 18 ft lbs first then torque to Jerrys' figures
Jerry
President
President
#5 PostAuthor: Jerry » Sun Jul 30, 2006 3:42 pm
Smart Alec!! I forgot all about a sequence - sorry!
debben1
#6 PostAuthor: debben1 » Mon Jul 31, 2006 9:39 am
11ft lbs is a little bit excessive for 6mm bolts into 30 year old cast alloy, and using a torque wrench will give you very little feel, we see a lot of stripped threads in this are. If you have a torque metre then use inch pounds, about 65 inch lbs is sufficent, Regards, Steve
#7 PostAuthor: chrisNI » Mon Jul 31, 2006 11:20 am
Tell me about it... I bust more than a few cam cap bolts before reading Steve's article in the last magazine properly!
kiwiz
#8 PostAuthor: kiwiz » Tue Aug 01, 2006 2:48 am
For a complete idiot are inch pounds foot pounds multiplied by 12?
rickman CRR
#9 PostAuthor: rickman CRR » Tue Aug 01, 2006 9:59 am
Inch pounds are divided by 12 to get the Foot Pounds.
So 65 inch/pounds as recommended by Debben = 5.41 ft/lbs
You may find that 5.41 ft pounds is difficult to set on a wrench designed for a higher range of torque settings.
hanskloss
#10 PostAuthor: hanskloss » Tue Aug 01, 2006 10:19 pm
great thread, I've checked mine on Saturday and all 12 needed retorquing, I've done the head gasket replacement and overhaul 800miles ago, thanks guys
Users browsing this forum: moizeau and 41 guests
