Front Brake Calipers
I own a Z1000R2 1984. I want to change the front calipers and still use the exisitng discs. Does anybody know which type of four pot calipers to use?
- london calling
Easiest up-grade if you're keeping the original discs is to re-build your existing calipers,fit braided hoses,good pads and a modern master cylinder such as ZZR,etc.
If you fitted a GPz750/1100 UNI-TRAK 18" front wheel,this has the same PCD as the Yamaha R1,R6,Thunderace,etc which have 300mm discs and are much lighter than your original Kawasaki discs.
Jack
Hello Gaz, your stock brake set up is a fixed disc with a floating caliper, most four pots are fixed and use a floating disc. Its not a good idea to use a fixed disc and a fixed caliper, although it has been done many times, but you would not catch a reputable manufacturer compromising the brake system in this manner. You shouldnt use a floating caliper and a floating disc together either. So if you want to use the more modern 4 piston fixed calipers you should really swap the discs over to the floating type. Steve
