Points cover paint
- steve bowdler
Points cover paint
Hi what do you guys use for the black on the points cover enamel , or just a gloss black ? Ta
Gloss enamel Steve.
Do a nice thin brush coat getting into the corners and allow to dry for a short while. Put brake cleaner or lighter fluid on an industrial type paper towel. Stretch it over a flat wooden baton and wipe over changing the towel after each pass.
Repeat as necessary. Two coats should be enough.
- steve bowdler
