I've heard so much about different carbs that are easy to fit and set up on a Z900 A4 - does anyone have actual first hand recommendations?
I've got a Yoshi style pipe now, so I reckon a bit of extra breathing space is required!
A4 alternative carb suggestions?
1976 z900 A4 -- Now, with a little help from Wiseco and Steve Debben, it's a 1048 with rs34 flatsides
I have 28mm Z1R carbs on my A4, and is running on standard pipes - all seems ok: no leaks or problems.
Been running Z1R 28mms for 50k miles no problems
Only 1 fuel pipe to these carbs so you need to block 1, if your tap feeds for 2 , and for safety I bored out the fuel feed brass pipe in the tap , where the fuel hose pushes on, an extra 1mm width will make the single feed much more likely to feed what the carbs need , without making the brass too thin. drill it in 0.5 mm increments with the tap in bits and it's easy.
( or use a Z1R tap)
can't remember the current jets but John Browse was helpful i seem to remember
( or use a Z1R tap)
gray
Users browsing this forum: Kwackman, Mark Tiller and 34 guests
