Z1000 mk2
- big green bus
Z1000 mk2
Can you still get replacement needles for standard carbs? the ones on this are damaged .
You could try Allens performance, or motocarb . Have phoned up and used both in the past, found both helpful. Bought a set of Keihin carbs off Allens, and VM28 carb parts for another bike off motocarb.
http://www.allensperformance.co.uk/
http://www.motocarb.co.uk/
Re: Z1000 mk2
big green bus wrote:Can you still get replacement needles for standard carbs? the ones on this are damaged .
I would try NRP in Manchester as the helped me out with carb parts for Mark 2
http://www.nrp-carbs.co.uk/
The trick is to get the correct needles & needle jets as both items wear out
Also the needle & jet no.s differ depending whether it is a UK or US spec Mark2
Users browsing this forum: Kwackman, Mark Tiller and 43 guests
