camchain problems
rsullivan
camchain problems
#1 PostAuthor: rsullivan » Thu Jun 28, 2012 6:37 pm
Looking for a bit of direction on a problem. I have just replaced the camchain on my 1977 A1 But when turning the motor over to let the Tensioner take up the chain tension i find the chain tries to ride up over the inlet cam. its as if the Tensioner is not long enough to keep the chain tight. all parts are new ie roller ect only the Tensioner is original although when i bought the bike this was not fitted so wondering if it is correct one, anyone got any ideas. thanks roy
hanskloss
#2 PostAuthor: hanskloss » Thu Jun 28, 2012 6:51 pm
best remove the tensioner and measure how deep can you push the roller (ie push it with a pencil and mark), than compare if freed tensioner extends further than measured length, also you could take a photo of the tensioner
prowlerz1
#3 PostAuthor: prowlerz1 » Thu Jun 28, 2012 8:34 pm
how many links in the replacement chain should be 122 links
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
hillbilly
#4 PostAuthor: hillbilly » Thu Jun 28, 2012 8:54 pm
is the cam chain on the crank teeth,or running on the side of it.as in not on the teeth.
zman
#5 PostAuthor: zman » Fri Jun 29, 2012 12:32 pm
I had the same problem. :(
I solved this by removing the tensioner.Then using the Handel end of a small screw driver pushed the tensioner well onto the chain.Then put tensioner back,released it ,locked it of,sorted :)
You will fined this technique hard to fined in the workshop manual.But it worked for me :)
keep thoses wheels turning
