headlamp blowing
headlamp blowing
what could be making my headlamp blow, its not the pilot light or the high beam just the main light part of the bulb,
and which wire is it , is it red/yellow or black/yellow
any suggestions to check.
- ZedHead
I think Red/Black is high, Red/Yellow is low and Black/Yellow is earth, if it's only the low beam check through the Red/Yellow starting with the connection to the bulb itself and work back it's probably shorting out somewhere where the live and earth are close, Headlamp/connector blocks/handlebar switch gear.
I lost both main beams myself in Germany which turned out to be a break in the wire just where it enters the fuse box, I don't think it'll be that on yours as I think the Z1 is a little different.
Check battery voltage at about 2.5k revs should be 14.6 volts dc,if not and is higher could be voltage regulator faullty
- steve bowdler
- z1000puddin
- DogsbolloxofZ1B
