plastic rings
mikey
plastic rings
#1 PostAuthor: mikey » Tue Jul 24, 2012 7:32 pm
As per title, they go inside the screw on bit that holds the HT leads in the coils, need 4 if anyone got any please.
#2 PostAuthor: z1bman » Tue Jul 24, 2012 10:10 pm
not available as a separate part unless someone has an old coil. i would just trim back the coil wire about 12mm + coat the outside of the lead with some silicone. push the lead into the coil with some pliers then tighten the plastic nut
mikey
#3 PostAuthor: mikey » Wed Jul 25, 2012 8:14 pm
Cheers for that but i found mine
in the really safe place i put them many months ago :roll:
Users browsing this forum: Bing [Bot] and 33 guests
