Newbie with Swingarm question - Metchamex?
Charlie
#16 PostAuthor: Charlie » Thu Jul 19, 2012 5:08 pm
My Metmachex low brace swinger uses standard spacers on the Metmachex wheel spindle ( the spindle is keyed to work with the concentric adjusters) and has needle rollers at the pivot end.
sled
#17 PostAuthor: sled » Fri Jul 20, 2012 10:22 am
thanks Steve and Charlie big help :up
haven't heard back from Metmachex
keen to see some pics if you got any charlie?
Charlie
#18 PostAuthor: Charlie » Fri Jul 20, 2012 3:53 pm
sled wrote:thanks Steve and Charlie big help :up
The bike is not at mine at present, nor is the swing arm (it isn't fitted at the moment) cos I am having some brackets added and then it's back off for polishing.
Identical to this though
Gus
#19 PostAuthor: Gus » Sat Jul 21, 2012 10:27 am
"Set the GRINDER on it"
sled
#20 PostAuthor: sled » Sat Jul 21, 2012 9:56 pm
They do look nice. I am only assuming they still manufacture this ?? haven't heard back will need to resend email. It save a lot of friggn around to be able to use the standard standard spacers.
Not sure about CB900f trying to find out about this stuff myself
I assume a 160 tyre will only fit with offset sprockets and chain conversion. Any one know how to set up the drum brakes with this combo
thanks for the help pretty keen on these think they are nicer over PMC
sled
#21 PostAuthor: sled » Sun Jul 22, 2012 11:49 pm
Charlie
thanks for posts one last Q are you running standard length shocks?
cheers Jason
Charlie
#22 PostAuthor: Charlie » Mon Jul 23, 2012 4:09 pm
sled wrote:Charlie
cheers Jason
I have done std. rear shox (IIRC std is 320mm), but the ones on at the mo' are 335mm rebuilt Marzocchi Strada's. I also have a set of 365mm rebuilt Strada's as well. They all go on and fit OK.
I may have cornered the market on friggin used Marzocchi Strada's :lol: In addition to the two rebuilt sets I have, I possibly have another 3 or 4 sets in various states of disassembly out in the shed as well :D I kept buying shocks to rebuild but sometimes only one was good...so I bought more and more until I had 2 as new sets and a load of spares....
sled
#23 PostAuthor: sled » Mon Jul 23, 2012 8:56 pm
:D haha i always say its good to have spares! The boss cracked it the other day saying the postman knows her buy name and just said "another part" :lol:
Not many stradas down here i bought a set of YSS 350mm but was thinking they might be a bit long for the swing arm so might have to move the mounts back I could possibly swap them over to 330? they can be length adjusted 30mm I am using standard mounts im in two minds whether to rake the top mounts or not? I know i said one last Q???? does the 365 jack the rear up high? or look ok?
sent another email to metmachex so hopefully soon
thank Jason
Charlie
#24 PostAuthor: Charlie » Tue Jul 24, 2012 5:27 pm
Yeah the 365mm shox do shove the back up, but not so as it starts looking silly I dont think. It's only about 1.5/1.75" over stock anyway and when someone is on it, it just squats down as normal. If I didn't tell anyone, I doubt they would even notice as the bike is not stock anyway :wink:
Really if I am honest I probably run the 335mm shox cos I had those shock bodies powder coated whereas on the 365mm shocks, the bodies are just painted...and the powder coated finish is more durable than the painted one.
Springs and spring seats are powder coated on both sets so that is not an issue.
This is a last years pic of the 335mm units on the stock swinger with the rear mudguard already removed and a Z Power under tail kit (from a Z900) fitted. ( sorry about the rim tape :lol: ) The engine bars have gone now too.
.. another inch or thereabouts on top of that ^^ makes very little visual difference really.
sled
#25 PostAuthor: sled » Thu Jul 26, 2012 2:24 am
Hey Charlie
Thanks for the replies and pics 650 looks good. like the fender eliminator Zpower you say will take a look.
Have had several responses from metmachex very helpful they say that the standard off shelf low brace z900 wont fit a 160 and will there fore need a custom arm. Waiting on shock mount dimensions (length and height) before going ahead. But pretty much the same as yours. If the shock is positioned further back than standard mounts i might stick with my new 350mm YSS if not i may have to box em up and ask for 340s :roll: Not sure how they will take that??? Will keep you posted how it progresses.
thanks Jason
Dodgy Z1B
#26 PostAuthor: Dodgy Z1B » Thu Jul 26, 2012 1:24 pm
Still think its not a metmachex had 4 of these over the years on different bikes and still have one on a gs750 and my z1b the rear adjusters are nothing like the one in the picture. They are all like this http://www.metmachex.net/p3_10_1.htm
sled
#27 PostAuthor: sled » Sat Jul 28, 2012 9:46 pm
Hey Dodgy one, you are right Metchamex said it was not theirs a copy of their design by Davida. I am in conversation with them just trying to work out style adjusters etc don't know if should go 1" over or not?
cheers
Users browsing this forum: sockpuppet and 44 guests
