Z1b float hight? using the upside down method
uk kev
#1 PostAuthor: uk kev » Mon Aug 20, 2012 7:46 pm
Can anybody give me the hight to the top of float using the upside down method, measuring from the gasket face of the carb body, in mm's please.
Thanks.
#2 PostAuthor: z1bman » Mon Aug 20, 2012 9:07 pm
kawasaki do not recommend a float hight only a fuel level checked with special tool
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Mon Aug 20, 2012 10:16 pm
Its not April fools is it :?: :D :D :D :D :D :D :D :D :D :D Wouldn't arf make a mess :D
Bruce Sexton
#4 PostAuthor: Bruce Sexton » Tue Aug 21, 2012 12:10 pm
I set my Z1a up at 21mm using the upside down method. not had any problems to date.
Bruce
jimmock
#5 PostAuthor: jimmock » Tue Aug 21, 2012 12:32 pm
Bruce Sexton wrote:I set my Z1a up at 21mm using the upside down method. not had any problems to date.
Bruce
Bruce,
Do you take the mirrors off first??
Jimmock. :wnkr
I hate people I don't like !
uk kev
#6 PostAuthor: uk kev » Tue Aug 21, 2012 5:43 pm
Bruce
Thanks Bruce, I have done mine about the same.
Bruce Sexton
#7 PostAuthor: Bruce Sexton » Wed Aug 22, 2012 1:26 pm
Bruce
Bruce,
No you don't need to take them off, just angle them away so you dont end up looking up your own arse :P
and careful you dont scratch your paintwork.
Bruce
Garn 1
#8 PostAuthor: Garn 1 » Wed Aug 22, 2012 7:11 pm
Clymer (end of Chap7) has a list of settings from '73 Z1 thru to '79 Z1000,
They recommend ..all Z1, Z1A & Z1B have float levels set at 24 mm +- lmm.
That's 3.5 mm down from the bottom-most flange of the carb top!
Must admit, I often have needle & seat leaking troubles, even after replacing them.
I always think there is more pressure on the needle to seat, if the levels are set, such that the float will trying to force them together! Am I correct?
