Fork Leg holding tool - Z1000R etc
martinz1000r
anyone got the tool that you stick down the fork leg to stop the damper spinning when you trying to undo the allen bolt in the bottom of the leg. I am trying to change a stanchion. Anyone got one I can borrow? Happy to cover costs.
Either that or the recommended work around please!
- paul doran
martinz1000r
paul doran wrote:Martin use a brush handle
if You force it down on the damper rod it is usually sufficent to stop it spinning
i did wonder about that but was worried about it splintering.
- paul doran
martinz1000r
that worked! Just got to explain to Mrs S now why her broom has horrid black sludge all down the handle. Should have used one from the garden rather than the kitchen!!
Oops
Oops
martinz1000r
Ginger Bear wrote:Martin, I'd guess by the lack of your 'on-line' presence for the last few hours that Mrs S is dealing with you right now!![]()
She hasn't noticed yet! Not sure what was worse; the smell of old oil or the Gunk i used to try and clean it up......
25 year old fork oil absolutely stinks
