I've been searching but don't seem to be getting far, but there must be some.
I'm looking for a picture of a Z650 with either a single sided swing arm or a mono shock.
questions being,
Which swing arm?
z650 single sided or mono shock info wanted please
Life is not a trial run
http://forums.kz650.info/index.php?topic=2232.0
http://www.oldskoolperformance.com/foru ... &start=154
2 minutes googling found these, there will be loads on other sites
Crofty wrote:http://forums.kz650.info/index.php?topic=2232.0
you did well young Luke.
However the first link won't let me in as not a member and the second is of a Z1
I have also found similar whilst Googling and surfing. but Z650 seem more illusive , but thank you and I'll join the first link sight in search of my quest
tried to join KZ forum but apparently I'm SPAM, yet I don't even like the stuff!
Click the KZ Info logo at the top of the page and it'll let you into the forum
Koreanbaz wrote:Crofty wrote:http://forums.kz650.info/index.php?topic=2232.0
fook me, if they let ME in they'll let you in!!
Second is actually a Z650 frame with an 1100 engine in, it does not have the mount on the lower frame rail under the engine.
GPZ750 unitrac arm might fit, you need to get a tape measure out and go check a few arms, at the end of the day there will be lots that fit, just depends how much work you want to do.
Users browsing this forum: Bing [Bot] and 49 guests
