Cam chain front guide removal
#1 PostAuthor: ZedHead » Sat Sep 22, 2012 11:36 am
Trying to remove the single Philips head bolt that holds the front cam chain guide in place but the little blighter wont budge. Any tips on how to get it out without causing too much damage?
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Sat Sep 22, 2012 12:04 pm
You should be able to move it with an impact driver.
Regards
Steve
750steve
#3 PostAuthor: 750steve » Sat Sep 22, 2012 12:08 pm
& use a heat gun around the alloy surrounding it
#4 PostAuthor: ZedHead » Sat Sep 22, 2012 2:16 pm
Thanks guys - I have tried heat and an Impact driver and it still wont budge. It looks like I am either going to have to get a bolt or something welded to the top or drill it and helicoil it .... bugger !
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Sat Sep 22, 2012 4:22 pm
Don't try and drill it take it into an engineering shop and get them to do it.
Regards
Steve
KeithZ1R
#6 PostAuthor: KeithZ1R » Sat Sep 22, 2012 4:45 pm
Got one out by "converting" the chewed phillips to a straight screw followed by a large straight driver with mole grips clamped on the shaft :) the second I bought an air impact gun :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#7 PostAuthor: PAULJAC47 » Sat Sep 22, 2012 5:20 pm
Try some left hand cut drills,starting at the smallest size and working gradually up ,i have had quite a bit of success with these,a bit of luck and it will spin out as the size gets bigger or with care you will get big enough to pick out remains of threads..good luck..
#8 PostAuthor: ZedHead » Fri Sep 28, 2012 3:46 pm
Thanks to everyone for the tips. I managed to get it out today using a combination of penetrating fluid, heat and left hand drills. It finally unscrewed on the end of a 4mm LH drill - No thread repair needed :D
Users browsing this forum: Maunders and 61 guests
