Looking for some sage advice and wise council
I am about to pull the trigger and order a set of smooth bores.
What is the consensus as to which carb is best suited for road use on the Z1000J with Wiseco big bore kit and APE cams
The Mikuni Flat Slide Smooth Bore 34mm kit ref RS34-D21 K
or the
The Keihin Flat Slide Smooth Bore 35mm kit ref CR35
Opinions wanted ~ Mikuni versus Keihin carbs
In my shed
2013 KTM 1190 Adv
2012 MV Agusta Brutale
2011 Ducati Multistrada 1200
2010 KTM990 SMT
1981 Z1000J
1980 H**** CB900F
2013 KTM 1190 Adv
2010 KTM990 SMT
1981 Z1000J
1980 H**** CB900F
I have Keihin 31mm CRS on my Z1000A2, with 1075 wiseco big bore kit, ported Z1000J head, kent cams.
The bike runs really well, apparently they can be a devil to set up.
Some folk on here do not like the Keihin CRS carbs because of this.
Debben performance in Ringwood set the carbs up. I understand the larger the carbs you fit, the harder they are to tune for low revs.
Give Ray a bell at debben performance, or send him an e-mail for advice.
wild_zed wrote: Z-enterprises have offered me a good price on a set of 34mm Mikuni's
Which 34mm Mikuni`s ? RS or TM - I assume. Because would not want CV`s on there.
wild_zed wrote:Not the diaphram type
These "RS"
Good luck, I am sure they will work fine.
