SET OF CAM CAPS Z900/1000
#16 PostAuthor: Pigford » Mon Oct 08, 2012 9:21 am
Cheers Mr Puffin - me bid is in :wink:
#17 PostAuthor: ADRIAN H » Mon Oct 08, 2012 5:46 pm
I believe I have a set of caps from a Z1000A2 head.
I will check tomorrow lunch time and send you a text.
Adrian
#18 PostAuthor: Ginger Bear » Mon Oct 08, 2012 6:16 pm
Just like buses eh Piggy......... Non for ages then two come along at once. :roll:
# 104
#19 PostAuthor: Pigford » Mon Oct 08, 2012 6:48 pm
ADRIAN H wrote:I believe I have a set of caps from a Z1000A2 head.
Adrian
Wow = Cheers Adrian :P
Mr Puffin
#20 PostAuthor: Mr Puffin » Mon Oct 08, 2012 9:14 pm
Pigford wrote:Cheers Mr Puffin - me bid is in :wink:
No Problem good to be able to help :) and im searching for J/GPZ set for my spare head so allways have my eyes open. Looks like your sorted closer to home so good result
By the way same seller has a set of cam shell bearingslisted :wink:
Ginger Bear wrote:Just like buses eh Piggy......... Non for ages then two come along at once. :roll:
Seems to be allways the case :??
#21 PostAuthor: Pigford » Wed Oct 17, 2012 12:50 pm
Many thanx to Arian for sorting me out a set of caps :P
First impressions look good - but need a set of 4 x shells to accurately check fitment :!:
#22 PostAuthor: ADRIAN H » Wed Oct 17, 2012 7:57 pm
Glad you got them. Fingers crossed you can use them.
IanM63
#23 PostAuthor: IanM63 » Thu Oct 18, 2012 8:44 pm
Pigford wrote:[b]but need a set of 4 x shells to accurately check fitment :!:
How ya gonna do that Mark? Plastigauge? Just curious cos one of mine is supect. :??
IanM63
#24 PostAuthor: IanM63 » Thu Oct 18, 2012 8:53 pm
#25 PostAuthor: Pigford » Fri Oct 19, 2012 7:36 am
Once I have some shells - I'll remove the valves and set it up with the cams & check they turn by hand. I will also visually check clearance by eye in a dim room with a torch :shock: Sounds stupid, but you can see any gaps by the light :wink:
These bikes are so old now, 99% of them are running with excessive cam clearances - so as long as they ain't tight - should be OK :!:
Obviously, if the bike runs noisy then I'd have to do the plastigauge bit :evil:
#26 PostAuthor: Ginger Bear » Mon Oct 22, 2012 7:36 pm
Piggy, I was watching these for meself. :roll:
http://www.ebay.co.uk/itm/380491805249? ... 1423.l2649
Let me know if you plan to bid on 'em. :wink:
# 104
#27 PostAuthor: Pigford » Mon Oct 22, 2012 7:38 pm
Cheers Bear :wink:
Users browsing this forum: rpeters and 26 guests
