Flat liner!
steve.w
#16 PostAuthor: steve.w » Sat Oct 27, 2012 4:05 pm
stick some easy start up its arse :wink:
Mark Tiller
#17 PostAuthor: Mark Tiller » Sat Oct 27, 2012 4:49 pm
Have u changed the plugs and put fresh fuel in?
07962421462
PaulMceleney
Chunks
#18 PostAuthor: PaulMceleney » Sat Oct 27, 2012 5:59 pm
my bike was standing for while would not start sprayed some easy start into the petrol tank then it started ,you can spray on to your k n filters
bomber
#19 PostAuthor: bomber » Sat Oct 27, 2012 6:07 pm
Mark Tiller wrote:Have u changed the plugs and put fresh fuel in?
plug change probably should have been the first thing, well second after fresh fuel but no i haven't changed em, just assumed they were new like everything else
but we all know that assumed....makes an ASS out of U and ME... innit!
i'll take a trip down to Halfords tomorra and buy some...and sum easy start,
Thanks m8y....X :wink:
bomber
#20 PostAuthor: bomber » Sat Oct 27, 2012 6:08 pm
yeh done that, unleaded is ok innit
Prrrrp!.......oops, better out than in..
bomber
#21 PostAuthor: bomber » Sat Oct 27, 2012 6:09 pm
paulmceleney wrote:my bike was standing for while would not start sprayed some easy start into the petrol tank then it started ,you can spray on to your k n filters
cheers, i'll try that tomorra
bomber
#22 PostAuthor: bomber » Sat Oct 27, 2012 6:13 pm
steve.w wrote:stick some easy start up its arse :wink:
Fuxake dawg, is ther anywhere you can't put this easy start stuff,
can you sniff it or smoke it? :lol:
maybe a drop on the dip stick will put a smile on my face if the bike wont start... :P
steve.w
#23 PostAuthor: steve.w » Sat Oct 27, 2012 6:17 pm
mint lol just spray it over the back of the carbs sparingley i flattened a bat 3 times on a gpz 750 would it feck fire up..then give it a sniff ..started on the button everytime after :wink:
bomber
#24 PostAuthor: bomber » Sat Oct 27, 2012 6:19 pm
z1bman wrote:low tension wires green. + yellow with red trace = coil no 1+4 black. + yellow with red trace = 2+3 coil
Thanks Pal, you're a star..seems the green and black were reversed but the batterys flat now so i'll try again later, so that would have made the plugs spark on the down stroke instead of the up...am i right?
you mentioned that earlier right!
i'll do a you tube vid when it starts so you can have a listen....
bomber
#25 PostAuthor: bomber » Sat Oct 27, 2012 6:22 pm
so its like hamyl nitrate for bikes? Cool!, i'm gettin a chubby on here, cant wait to have a sniff :P
#26 PostAuthor: Rich » Sat Oct 27, 2012 7:00 pm
have you lubed the ignition advancer - sounds like it's firing 180 degrees out to me.
bomber
SHE'S A RUNNER.... SHE'S A RUNNER! !!
#27 PostAuthor: bomber » Sat Oct 27, 2012 7:14 pm
WOOHOOO! she's a runner :clap :clap :clap :clap :clap
thanks for all the tips lads, i'll see you right when i get my new glasses...
now i'm a happy man !!!
steve.w
#28 PostAuthor: steve.w » Sat Oct 27, 2012 7:17 pm
so was it the sniff mate :shock:
bomber
#29 PostAuthor: bomber » Sat Oct 27, 2012 7:22 pm
steve.w wrote:so was it the sniff mate :shock:
no i tried it again with battery of my GS and it fired in,
the problem was the green and black LT leads were arse about face,
i think i've got carbon monoxide poisoning now tho..... open doors now .....breath!!!!
bomber
#30 PostAuthor: bomber » Sat Oct 27, 2012 7:27 pm
Rich wrote:have you lubed the ignition advancer - sounds like it's firing 180 degrees out to me.
No sorry Rich, i wouldn't know where to find it but no need now, she fired up.
i do need to have a look at the timing next tho i think, she's a bit lumpy!
