Flat liner!
- Mark Tiller
PaulMceleney
- Chunks
Mark Tiller wrote:Have u changed the plugs and put fresh fuel in?
plug change probably should have been the first thing, well second after fresh fuel but no i haven't changed em, just assumed they were new like everything else
but we all know that assumed....makes an ASS out of U and ME... innit!
i'll take a trip down to Halfords tomorra and buy some...and sum easy start,
Thanks m8y....X
mint lol just spray it over the back of the carbs sparingley i flattened a bat 3 times on a gpz 750 would it feck fire up..then give it a sniff ..started on the button everytime afterbomber wrote:steve.w wrote:stick some easy start up its arse
Fuxake dawg, is ther anywhere you can't put this easy start stuff,
can you sniff it or smoke it?![]()
maybe a drop on the dip stick will put a smile on my face if the bike wont start...
z1bman wrote:low tension wires green. + yellow with red trace = coil no 1+4 black. + yellow with red trace = 2+3 coil
Thanks Pal, you're a star..seems the green and black were reversed but the batterys flat now so i'll try again later, so that would have made the plugs spark on the down stroke instead of the up...am i right?
you mentioned that earlier right!
i'll do a you tube vid when it starts so you can have a listen....
Prrrrp!.......oops, better out than in..
steve.w wrote:mint lol just spray it over the back of the carbs sparingley i flattened a bat 3 times on a gpz 750 would it feck fire up..then give it a sniff ..started on the button everytime afterbomber wrote:steve.w wrote:stick some easy start up its arse
so its like hamyl nitrate for bikes? Cool!, i'm gettin a chubby on here, cant wait to have a sniff
SHE'S A RUNNER.... SHE'S A RUNNER! !!
WOOHOOO! she's a runner
thanks for all the tips lads, i'll see you right when i get my new glasses...
now i'm a happy man !!!
