barrels question
clive1
barrels question
#1 PostAuthor: clive1 » Sat Oct 27, 2012 12:57 pm
Hi guys, does anyone know if there should be o rings on the bottom sleeves of the liners on my 1977 z1000 a1, i just ask because there seems to be on the z900 barrels acording to the haynes manual but i have the factory manuel for my bike and theres no mention of them is this right or have i missed something.
cheers.
clive.
PaulMceleney
Chunks
#2 PostAuthor: PaulMceleney » Sat Oct 27, 2012 6:08 pm
just had a look at the barrels that i have ,and there is a groove in the two set i have and they are of a z1000 a1 so yes
#3 PostAuthor: z1bman » Sat Oct 27, 2012 6:16 pm
KAWASAKI MOTORCYCLE PARTS
Select Language
English
Assembly
CYLINDER/PISTONS/CRANKSHAFT ('77-'78 A1/
KZ1000-A1 KZ1000 (1977)
clive1
#4 PostAuthor: clive1 » Sat Oct 27, 2012 6:35 pm
thanks guys for that info, my barrels dont have a recess for a o ring to fit into is this significant ?
#5 PostAuthor: z1bman » Sat Oct 27, 2012 6:42 pm
no recess no o ring
#6 PostAuthor: chrisu » Sat Oct 27, 2012 8:29 pm
don't need them anyway.............
#7 PostAuthor: Pigford » Sun Oct 28, 2012 2:21 pm
chrisu wrote:don't need them anyway.............
+ 1 ... waste of effort :!:
clive1
#8 PostAuthor: clive1 » Sun Oct 28, 2012 7:30 pm
How so, ? they look quite handy for sealing the sleeves.
#9 PostAuthor: Pigford » Sun Oct 28, 2012 7:33 pm
clive1 wrote:How so, ? they look quite handy for sealing the sleeves.
The base gasket stops leaks between barrel & casings.
If the liners are leaking - thats bad news and an "O" ring is a short-term fix :!:
Most people don't bother with them as no leaks are apparent when not fitted. No harm fitting them if you want :wink:
clive1
#10 PostAuthor: clive1 » Sun Oct 28, 2012 8:43 pm
cheers for that, just puts my mind at rest ,
