bolt part no's
wayno
bolt part no's
#1 PostAuthor: wayno » Tue Nov 06, 2012 4:38 pm
what are the part no's for the bolts holding the lower engine mounting plate to the frame and also the two mounting brackets for the battery box/rear brake switch, looked at various parts diagrams but cannot be certain. dimensions would be ok if no part no's.
cheers wayne
jimmock
#2 PostAuthor: jimmock » Tue Nov 06, 2012 5:40 pm
Wayno,
Get stainless ones!!!
Jimmock. :wnkr
I hate people I don't like !
wayno
#3 PostAuthor: wayno » Tue Nov 06, 2012 6:17 pm
jimmock wrote:Wayno,
i am considering that option, gonna see if i can get the correct ones 1st, got the heads ground down and polished at work for the chain adjuster block bolts and was impressed the way they came out
Steve Cooke
#4 PostAuthor: Steve Cooke » Tue Nov 06, 2012 7:25 pm
Lower bolts 2 x M8 X 18 Part no. 110B0818
Not quite sure which other mounting brackets you mean or which model, but if it's the rear engine mounts the numbers are :-
Z1/Z1A = L/H 32030-027
R/H 32030-028
Z1B = L/H 32030-046
R/H 32030-045
A4 = L/H 32030-055
R/H 32030-056
A1/A2 = L/H 32030-066
R/H 32030-067
wayno
#5 PostAuthor: wayno » Wed Nov 07, 2012 11:45 am
https://www.kawasakiepc.com/SystemSearc ... N=38256406
part no's i need are in section 15 for the bolts to the frame for 43,44 and 47. these are for a z900 a4
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Wed Nov 07, 2012 2:08 pm
The BZP version of these M8 bolts c/w the correct head size should be available from Yambits.
Regards
Steve
Re: bolt part no's
#7 PostAuthor: ADRIAN H » Wed Nov 07, 2012 8:13 pm
wayno wrote:what are the part no's for the bolts holding the lower engine mounting plate to the frame and also the two mounting brackets for the battery box/rear brake switch, looked at various parts diagrams but cannot be certain. dimensions would be ok if no part no's.
cheers wayne
Which bike and year is this for.
wayno
Re: bolt part no's
#8 PostAuthor: wayno » Wed Nov 07, 2012 10:00 pm
cheers wayne
z900a4 1976
wayno
#9 PostAuthor: wayno » Thu Nov 08, 2012 12:22 pm
Steven Cooke wrote:Lower bolts 2 x M8 X 18 Part no. 110B0818
A4 = L/H 32030-055
R/H 32030-056
Ran the part no 110b0818 through the cross ref software but not recognised,
the other numbers are for the brackets, i needed the bolt no's. got them from the z1000 drawings.
thanks for the replies
#10 PostAuthor: ADRIAN H » Thu Nov 08, 2012 8:15 pm
In the downloads section of this site there is a parts list for z900 a4, along with other useful stuff.
http://www.classickawasaki.se/
#11 PostAuthor: Pigford » Thu Nov 08, 2012 8:17 pm
Just use proper s/s allen bolts :roll:
