z1100r hydraulic clutch conversion
- rc30rob
- Regular Poster
Hi all has anyone done this conversion on an ELR or know anything about it ,ie slave cylinder to use etc,thanks rob
Nolite id ,cogere ,cape malleum majorem
If you use a 33mm dia slave (zxr etc) use a 5/8 bore m/c it will give you more movement. Ducati slaves are 25mm bore and will fit your clutch rod nicely use a 14mm m/c with these. Slaves are available from Germany to fit inside std covers ( probably from USA as well) ask Padders - he's bought one.
If you want strong springs and light clutch try and find a P&M clutch actuator.
